メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2018年に発売されたSamsung Galaxy A7スマートフォンの2018年モデル。
My power button is not working
When I press my power button it doesn't turn on or off. How to fix it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
2 件のコメント
Power button is working but fingerprint is not working
さんによる
コメントを追加
1 件の回答
最も参考になった回答
@muhammadal69023 you need to check the mechanical part of the power switch to make sure that it actually closes the contact. If that looks like it is working, then replace the power button flex. Since iFixit does not have a guide for this yet, use something like this for that. The power button flex also has the fingerprint sensor on it. It is readily available at many online stores.
If that should not resolve it, you will need to check your mainboard for a missing/failed component. Start with your power flex first.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Muhammad Ali さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 28
今までの合計 800
