Why battery draining down fast
Battery draining fast
Hi @aijazahmed
Try replacing the battery and check if that resolves the problem.
Here's a video that shows what to do.
Search online for B-H0 battery to find battery suppliers that suit you best.
このアンサーは役に立ちましたか?
First, check if the battery is bloated or not if it is bloated change it with a similar 4500mah battery.
If the battery is not bloated first change the app's background running setting to off from setting and stop other background processing you don't want.
Next, stop all unnecessary notifications and turn on the dark mode it boosts your phone battery life.
If it didn't work try replacing the battery and check if that resolves the problem.
このアンサーは役に立ちましたか?
過去 24時間: 4
過去 7 日: 10
過去 30 日: 75
今までの合計 2,738
9 件のコメント
Battery drains fast I am vivo phone
kishore kishore さんによる
@kishorekishore How old is your battery? Is this something new or has it been getting steadily worse? Have you considered @jayeff's advice to replace the battery?
Jerry Wheeler さんによる
Battery drain fast
Hashir Siddiqui さんによる
Battery draining issue
Gangadharaiah R さんによる
Very bad battery
Saguna Raghav さんによる
4件以上のコメントを表示
