メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2022年11月30日に発売。16GBまたは64GBのモデルがあり、それぞれBasicペンまたはPremiumペンが付属します。これまでのKindleタブレットの中で最大の10.2インチディスプレイを搭載しています。
How can I get battery replacement and replace it?
My Scribe is 1 year old and I abuse it pretty much daily. I read on it for about 8-10 hours a day and take notes on it too during the class, which is about 90 minutes per class (I have 8 classes). The heavy note taking is not my concern, it's the reading. I usually charge mine from 40%-80/85% like everyone suggested, but lately I see a difference in the battery's capacity and I have been charging it more often than usual. I know it's a pretty new device, but how can I get a new battery and replace it myself? The device seems to be fragile too, unlike paperwhite
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hi @apcsila
Here's a video that may help.
Take note that the screen is not held down by adhesive but rather it is clipped on instead, so perhaps the best method of removing it is to use some pry tools (examples only) to remove it from the base. Read the last comment posted below the video about the removal procedure.
As for the battery, searching online for Amazon (or Kindle) Scribe 2022 battery produces no results for suppliers of the battery, but perhaps you may be able to find a supplier once you have opened the tablet and found the battery model number (printed on the battery) and search for the battery model number instead. It is shown at 3:50 minutes into the video but it is too small and fuzzy (when enlarged) to make out what it says.
Assorted prying tools for all types of enclosure opening, cable unhooking, digitizer removal and more. A complete set of opening tools all in one kit, perfect for electronic repairs. For professionals and beginners alike.の画像
製品
Prying and Opening Tool Assortment
$9.95
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
A eso lo llamas un video para "ayudar" a reemplazar la batería? Más bien lo llamaría destrozar completamente el dispositivo. Ese video solo ayuda a saber como no abrirlo.
さんによる
コメントを追加
回答を追加する
apc sila さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 20
過去 30 日: 75
今までの合計 2,540
