Coffee Machine Water leak
Water leak under machine when making coffee!
Hi @jacciv
Here's the ifixit DeLonghi ESAM xxxx Solenoid Replacement guide that may help.
Use the guide to disassemble the coffee maker so that you can check where the water may be leaking from e.g split pipe or loose fitting etc.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 4
過去 30 日: 12
今までの合計 255
