メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Kenmore Refrigerator 596.7857*80*の基本情報および修理ガイドです。このモデルはドア内蔵型製氷機を備えておらず、自動霜取り機能と結露防止ヒーターのスイッチを搭載したボトムフリーザー冷蔵庫です。このページは、モデル番号が596.7857*80*と一致するすべてのモデルの情報を取り扱っています。
Not getting any ice
I have not been getting any ice, I have moved the shut off arm up and down a few times and waited 24 hours for it to make ice and have not gotten any ice. I don't know where the water filter is located so I haven't changed that. Any help you can give me is greatly appreciated. thank you
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi @edbakey
If there is no water/ice in the ice maker or if it is not working, first check if the freezer door switch is electrically OK and not that one set of contacts in the switch is corroded etc..
By design the ice maker does not function when the freezer door is open.
The freezer door switch is a changeover type switch which when the freezer door is opened, it releases to turn the freezer light on and the ice maker off and when the door is closed it re-operates to turn off the light and reconnect the power to the ice maker. It is the ice maker that turns the water inlet solenoid valve on and off as required.
Be safety aware if you decide to test if the switch is OK as there is 120V AC on the switch. It may be safer to disconnect the power to the refrigerator and use an Ohmmeter instead.
If the switch is faulty, search online for 12002646 to find suppliers that suit you best.
If the water inlet valve is faulty, search online for WP67003753 to find suppliers that suit you best.
Controls the flow of water into your refrigerator for ice-making and water dispensing functions.の画像
製品
Whirlpool SxS Refrigerator Water Inlet Valve - WP67003753
$73.99
Activates the interior refrigerator light when the door is opened.の画像
製品
Whirlpool Door Switch - W11396033
$27.99
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ed Bakey さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 19
今までの合計 242
