メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Kenmore製の家庭用洗濯機、Kenmore 80 Seriesの修理ガイド。
Dripping water into the machine
Hi there, love this machine - it's over 20 years old and strong! It just started dripping water into the machine tub. It's coming from the center where water fills the tub. Is this an easy repair or is it time to replace? I can do very minor repairs, but would most likely have to call in for service. Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi @tnodzak,
Sounds like a faulty water inlet solenoid valve.
Is it cold water or hot water that is dripping into the tub? Turn off the faucets that the washer hoses are connected to, one at a time to find out.
Repairs are relatively easy as long as you get the correct part.
What is the full model number of the washer?
With some models the valves come as a complete module unit i.e. both hot and cold valves and with others they are individual valves.
If a valve is faulty, it cannot be repaired. It has to be replaced.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thank you, Jayeff!
It just says Kenmore 80 Series and I don't have the manual as it came with the house in 2003.
I shut off the faucets then turned each cold/hot on individually and it doesn't seem to be leaking now...I'll see how it goes after the next load I run.
さんによる
@tnodzak
Kenmore washers can have the model number in a variety of places depending on who manufactured the washer.
For a top-loading Kenmore washer, try these locations to find your model number:
the back of the control panel
the upper-left hand corner of the back
the lower left-hand corner of the front
any stickers on the lid or inside corners
on the rim inside the lid (where an 80 Series should likely have it)
along the lower side panels
Also check the water inlet hose screen filters to see if they're broken, holed etc.
Usually they're located in the hose(s) screw fitting where it connects to the washer .
If they are broken what can happen is that any debris in the water supply e.g. sediment etc, can get lodged in the inlet valve(s) and this prevents it from closing properly when the machine shuts off the valve allowing water to drip into the machine
さんによる
コメントを追加
回答を追加する
T Nodzak さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 13
過去 30 日: 29
今までの合計 599
