メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iPad mini 5-モデルA2133のWi-Fi版のガイドです。2019年3月発売のiPad mini 5は、iPad mini 4の後継モデルです。
Replacement Battery Zero volts
Hi, my wife’s 3y/o iPad mini 5 died the other morning. Wouldn’t startup, wouldn’t charge.
I tried all the online suggestions but no joy.
I decided to replace the battery but first I removed the old one (partly to check my ability to do this ok) and found it at 0 volts.
So I ordered a new one and, before fitting, was surprised to find it also at 0 volts.
I wouldn’t have been too surprised but the spare battery I had ordered for my own iPad mini 2, two years ago, was still showing 3.5 volts.
However, the battery seller encouraged me to fit it and charge the device. I did this but no joy.
My real question is; “would you expect a NEW battery to arrive CHARGED?” ie. Is it possible I’ve been sold a dud battery?
Many thanks!
Kind regards, Mike.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
ベストアンサー
That battery is permanently damaged. It would be nearly impossible to restore a battery in that state of charge. Personally would keep pressuring the seller for a refund and get the battery from a more reputable place like here at iFixit or another place.
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
Many thanks Duck, I’ve got the refund and reordered through iFixit!
Much appreciated
さんによる
@mikefloutier No problem. Glad to help.
さんによる
Hi, it’s me again. I received your replacement battery and installed it but it still won’t start.
I’m now looking for other repair ideas.
さんによる
@mikefloutier best way to do that is by creating a new question. There, give all the details, background of the iPad and everything you have done and tried.
さんによる
コメントを追加
回答を追加する
Mike Floutier さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 7
過去 30 日: 27
今までの合計 561
