メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2023年に発売されたAppleのデスクトップ型コンピュータ、Mac Studioの修理ガイド、分解方法、トラブルシューティング情報。M2 MaxまたはM2 Ultraチップを搭載。モデル番号 A2901。
Is the SSD upgradable?
Can I upgrade the SSD drive myself or do I need to go through Apple?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
最も参考になった回答
I'm afraid it's not possible to upgrade it at all: "The Mac Studio (2023) doesn't have any upgradable components onboard. The M2 Max and M2 Ultra silicon, along with the SSD and unified memory, are all fused together on one motherboard." (XDA Developers)
このアンサーは役に立ちましたか?
スコア 3
13 件のコメント:
While we don't know if Apple altered things, heres a more detailed rundown on the M1 Studio Mac Studio Teardown: No Upgradable Storage … Yet
To be clear Apple is not using a SSD here! It's just using the raw Flash chips within a module. The controller logic is within the M Series SoC.
Some people have managed to transfer the Flash modules of the same size between systems, but it's not something easy nor something I would even try! Mac Studio Storage Removable
さんによる 共有
@danj Very interesting, but sadly still it looks like it's not an easy upgrade...
さんによる 共有
@dinoo_fixit - It's not a user upgradable system for sure!
Each Apple storage option has custom data held within the Flash of the primary unit. Unless you have access to the correct data set you can't can upgrade. At best you can swap-out the given set with the same size.
Big Tim's motto is buy not upgrade! Unlike Steve who believed in user upgradability when practical. Here this is more of a way to build to the desires of the market place as this system demand won't be high enough to commit entire system.
さんによる 共有
Apparently it is. Someone's just figured it out. I'm not going to plug but you might want to look around. I came here to see if you guys where offering this but obviously you arent - yet...
さんによる 共有
@seoras - If there is a will then someone is bound to figure it out. But in the same vane do you have the skills and tools to even attempt this brain surgery? Are you willing to waste your system when it fails?
For most of us it’s not worth the costs or risks! Often it’s cheaper finding a used or even new system and selling your current one to recoup some of the costs.
さんによる 共有
8件以上のコメントを表示
コメントを追加
回答を追加する
Icho Tolot さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 20
過去 30 日: 77
今までの合計 5,487
