How do I dislodge a cd from the player?
I have a cd stuck in my Bose CD player. The eject button on the remote will not dislodge it. I'd read, on U-Tube no less, a few years ago that shaking the player would work Didn't and seemed a rough solution.
Turn the power to the player off and on. Do not use the remote power-on button. You can do this by unplugging from the back of the unit and pluging it back in.
このアンサーは役に立ちましたか?
During the power on and off by plugging and unplugging from the device did not work the first time I did it one more time in and out with the plug and sure enough the disk came out. Thank you for your expert advice. This trick does work to dislodge a CD that will not eject. Peace
Stuck CDs can be caused by a number of faults.
# Shifted mechanism
Then figure out how to release the CD.
このアンサーは役に立ちましたか?
I'm shocked but the "Shaking it" suggestion actually worked! Here's what I did:
I didn't plan on fixing the unit today I was just dusting it off and removing it from its shelf so I could dust that. When I powered on again the Bose made its normal CD mechanism noises but about 1/4" of the CD came out so I grabbed it and out it came!
NOTE: I haven't tried inserting/playing a CD! I have the external 3 CD player from Bose (which is working fine) So for now I just won't play CD's directly from the Bose Wave Radio.
NOTE 2: :-) My curiosity got to me. Currently I can insert, play, eject, a CD from the main player.
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 62
過去 30 日: 175
今までの合計 5,527
3 件のコメント
I have this problem too. The CD will not eject. Any ideas how to get it to come out?
Kathica さんによる 共有
If the Drive is one with a tray. there will be a small hole on the face of the tray, usually on one side. Take a paper clip, bend it open and push it into the hole, like you would do to open the SIM tray on your phone.That should open the tray. If no tray, see my other answer.
bill さんによる 共有
My Bose will not take a disk in. Like the motor is dead. You hear a slight noise when the disk separates the sensor which would normally activate the motor to take the disk in. I took apart and manually inserted disk. It read and played the cd no problem. I hit eject but it wouldnt eject. Flashed ejecting on screen and then Said disk error when it wouldnt eject. If I hit eject again it would spin the disk up and play again. I replaced the motor but it did not fix anything. I have recapped the board. No change. Very frustrating.
Brian Arnold さんによる 共有
