メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Frigidair combo dryer starts and stops after a few seconds.
Model FLCE7522AW frigidair combo dryer starts and stops after a few seconds without any sounds or beeps. What can it be? Washer works perfectly fine.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
6 件のコメント
@krystalcol57696 at what point does it turn back on? Immediately or do you have to wait a while? What have you checked? Could be a failed thermostat etc.
さんによる
It does not turn back on once it has shut off, only turns back on if I press the start button again and then shuts down again after a few seconds.
さんによる
Mine does the same thing. Is there a picture or a diagram of where the thermostat and fuses would be located?
さんによる
Mine does the same thing. Is there a picture or diagram of where to find the thermostat and fuses? Model FLCE7522AW3
さんによる
Most dryers would have a similar schematic. There are thermal cutouts in a dryer but no fuses. See my above comment.
さんによる
1以上のコメントを表示
コメントを追加
2件の回答
最も参考になった回答
Hi @nicoledireso
Here's the service data sheet that may help.
Go to p.7 to see how to check if any error codes are stored by the dryer. The code will tell you what could be wrong.
If there are no error codes stored, go to p.6 and run the diagnostic tests and check if anything shows up during the tests.
If you find the problem is due to a faulty part that needs replacing, here's the parts list that is useful.
Locate the wanted part in the list and note the part number that is shown for the part. Search online for the part number only, to find suppliers that suit you best.
If you search on YouTube for (insert wanted part number) replacement, sometimes if you're lucky, you'll find videos showing how to remove/replace the part.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thank you so much! Do I need to hook the dryer up to some sort of meter to get the error code to display? I’m not quite understanding where the error code displays? Where does the error code display?
さんによる
@nicoledireso
See p.6 in the service data sheet linked above, section titled : "Understanding Error Codes" for how to interpret the blinking green and red LEDs above the Start/pause button to find out what the error code number is.
The error code list is on p.7→p.8
さんによる
コメントを追加
Is there any sign of heating? It could be a high limit thermo. It could be a problem with the heating coils.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
No :-( since it stops just seconds after starting, there is no sign of heat.
さんによる
コメントを追加
回答を追加する
Krystal Colon Maldonado さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 22
今までの合計 622
