How to remove/replace the volume/power cable inside the device?
Title. The cable assembly appears lodged between the back frame and the outer frame, and I cannot figure out how to get it out (and then replace it.)
Any help? Thank you!
Hi Davey,
I poked around but sorry to say I wasn't able to find any definitive answer for you; there just doesn't seem to be much information out there regarding 6a repairs.
My best guess is that you might have to take the rear cover off to get to the parts you need to access. One guy has a YouTube video where he does a pretty good job of tearing down the 6a, but unfortunately doesn't go as far as removing the volume/power buttons and cables. However, it does demonstrate how to remove the rear cover so that's something to consider as to whether that will help or not.
Google Pixel 6A Disassembly Teardown Repair Video Review - YouTube
Good luck, and let us know how it goes. Take lots of pictures and when you're done you can author your own iFixit guide showing others how to do that repair! Its fun and easy and will be appreciated by the community.
このアンサーは役に立ちましたか?
I removed the screen, the mb, battery, everything
I detatched the flex of the pwr/vlm button (its one with the flex and upper microphone)
And then i pushed the whole button section down a bit, until i was able to lift it up as you see in the picture.
Hope that helps.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 19
今までの合計 300
