メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
macOS対応のLG製27インチUltraFine 5K IPSモニター
Green tint on screen
Hey ifixit community,
I have a question about a 24” LG Ultrafine 5K Monitor. The screen shows a picture, but it is equally greenish tinted, see attached photo.
I tried 2 different MacBooks and different cables. Also the screen has 2x usb-C input and it doesn’t make a difference which one I’m using.
I assume it’s a hardware defect on the mainboard, the question is if the defect allows to narrow down, where to search on the mainboard.
Do you have an idea what could possibly be the problem?
Thanks!
画像
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
1件のコメント
Ti ho scritto la risposta più giù. Si può solo sostituire la M.B.
さんによる
コメントを追加
4件の回答
最も参考になった回答
Lukas, have you tried going into the monitor's settings and decreasing the value of the green tint (or increasing the red and blue tint to compensate)?
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Hi Shingle,
I tried different color profiles and settings, but not explicitly reducing the green value. Also, this would be just a work-around, I'm interested in fixing the hardware problem. It would be great to hear if somebody here knows, if this is common defect and usually caused by a resistor/capacitor or damaged chip - so if there is a reasonable chance to fix it without replacing the whole board.
Thanks
さんによる
@lukash72300 could be your Gamma IC or your video processor. Have you changed the input source? Something different then your MacBooks?
さんによる
コメントを追加
Hi @lukash72300 the same has happened to me today, suddenly, when connecting my laptop. I have tried updating the monitor’s firmware, connecting directly or through a Thunderbolt hub, changing color profiles, and connecting to two different MacBooks. The problem stays the same.
Did you find a solution? Thanks.
画像
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
Exactly the same for me. The only change I had is that I moved the screen from one room to another (but no drops, or hits, or anything).
Didi you manage to solve it?
さんによる
Hi Francisco, I had to give it to the official LG support here in the Netherlands, they fixed it for around EUR 320 and were faster than I expected. It came back in perfect condition, so I need to think it was money well spent in the end.
さんによる
@gianfranco52715 Thank you – I've sent mine to an authorized repair and they quoted me a similar fee for a new motherboard. Reading on the internet, it seems that the thunderbolt connector is poorly mounted onto the board and is rather fragile. I can't confirm it's that that got damaged, but it's a shame, because everything else is impeccable, still working, and the image overall is great. It's good news that a new MB can save all the material from going to waste, but a shame that it seems the board design/work isn't up to the quality of the rest of the display.
Thanks for the update!
さんによる
I also have this problem. Out of a sudden. Last time I will buy an LG-screen. Horrible.
さんによる
コメントを追加
Hi, I have a similar problem with an LG 27UD69-W from April 2017.
It gives a sort of 'square inside a square' ghost image that is really, really green.
Resets etc don't seem to help. Interestingly, it DOES seem to work without problems when it is significantly colder and critically less humid.
I suspect hardware somehow, maybe power leaking across a circuit it shouldn't through electromagnetic field, that is affected by humidity? (higher temp means more moisture can be held in the air, exponentially so).
It starts at around 22 degrees Celsius. If it's colder than that, the screen runs fine.
Since it's outside of warranty I expect LG won't help. Maybe something on the monitor's circuit board needs to be electromagnetically insulated.
But I'm not really a hardware guy, so these are just guesses. But I figured I'd post it here, you could try running it with an airco pointed at it or in a colder location and see if it helps.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Salve, vi dò io la risposta corretta e definitiva: SI DEVE OBBLIGATORIAMENTE SOSTITUIRE LA SCHEDA MADRE. È un chip andato, non dicono esattamente quale, am la devi sostituire tutta. Purtroppo ho speso 250€ circa. Non so se ne vale la pena, soprattutto per coloro che hanno comprato l'LG usato, ma non ci sono alternative. Purtroppo, e dico purtroppo, sul mio, ma a questo punto anche su molti altri apparecchi, avevo riscontrato la rottur senza spiegazioni della cornice esterna. Mi fu sostituito anche quella e dopo 1 anno è più rotta di quella di prima. Speravo di trovare un Teardown completo, ma non c'è nemmeno qui.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Lukas H さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 57
今までの合計 2,389
