メインコンテンツにスキップ
Model M7572 / 400 or 500 MHz G3 processor
45回答 すべてを表示
120GB hard drive into a pismo
I have what I thought was a compatible HD-a WD Scorpio Blue 120 GB and I've sucessfully disemboweled my Pismo powerbook (the old HD is an IBM travelstar 12GB). But the connector pins look really different on the new HD. Have I got the wrong thing? have I not removed something? The wide flat cable connecting the hard drive to the logic board is what I'm talking about. Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
a picture would help
さんによる
That sounds like my mistake- the drive is SATA not ATA/IDE. Thanks for the help!
さんによる
Del Rey, all you have left to do now , is to accept the answer that helped you the most. That way, anyone looking for an answer similar to your question, will know what worked. ;-) Good Luck
さんによる
コメントを追加
2件の回答
ベストアンサー
If it's not an ATA HD it's not right. ATA devices are also commonly called IDE, EIDE, Ultra-ATA, Ultra-DMA, ATAPI, PATA, (each of these acronyms actually do refer to very specific items, but are commonly interchanged). ATA connector is a two inch wide ribbon cable with 40-pin data connections and receive the 5V necessary to power them from the familiar 4-pin connection. (SATA NOT the same thing as ATA)SATA have a half inch wide, 7 “blade and beam” data connection, which results in a much thinner and easier to manage data cable. AFAIK the Scorpio Blue is a SATA drive.
If this Answer is helpful please remember to return and mark it Accepted.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
The Scorpio Blue is a SATA drive and will not work in your computer. You need an ATA/IDE drive. I would return the SATA drive and purchase the correct drive--good luck.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Here's the type of drive that will work: [リンクされた製品が存在しない、もしくは無効: IF107-008]?
Here's how to install it: PowerBook G3 Pismo Hard Drive Replacement
さんによる
is there any remedy (hack) to install a sata hd in a mac power book g 3 ?
さんによる
コメントを追加
回答を追加する
Del Rey さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 13
今までの合計 601
