メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
第2世代Apple Silicon(M2チップ)搭載、13.3インチRetinaディスプレイ搭載のMacbook Pro 13インチ用の修理ガイドと説明書です。モデルA2338です。2022年7月15日、WWDC2022でMacbook Air M2とともに初公開。
Screen Problem, blurred lines at bottom of screen.
Hello,
My Mac have developed some blurring at the bottom on the screen. It covers the entire width of the screen and is about 1/4" high.
I took it into Apple and they said it needed "screen controller" repair costing about $600.
Has anyone else had this issue and was able to perform a fix themselves.
Thanks
Andrew.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Sadly its out of warranty !!!!!!
さんによる
コメントを追加
2件の回答
Ouch! Your system should still be under warranty!
Double check if it is, then go to anther Apple store or dealer as this should be a free repair!
Unless there is visible damage around the displays chin area I can’t see any reason to be denied.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
さんによる
@andrewusherwood - If its just outside the window by a few weeks I would still press Apple, But you need to lean on them a bit. Be pleasant but firm, escalate it up the food chain, I'm sure you should be able to get this fixed for free!
さんによる
コメントを追加
I have the same problem, just just happen just I made an upgrade to Sonoma, I a few weeks after. Now, I don't know if its is hardware problem, or is it an software/driver issue. How can I tell, and take appropriate. I reverted to the original OS that come with the laptop, but the issue still persist.
Hope some can help..
Thanks
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
@georgetuges - Plug in an external display, if the image is clean on it, it tells us your internal displays logic is damaged and you likely need a new display assembly.
さんによる
コメントを追加
回答を追加する
Andrew Usherwood さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 29
今までの合計 1,010
