メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Dell Precision 5550ワークステーションは、Dell製のノートパソコンです。このページでは、Dell Precision 5550に関連する修理およびサービス情報を提供します。
Battery Replacement Not Accepted
Hello. I just received a replacement battery from iFixit, and my laptop won’t boot into windows with it installed. Placed the old battery back in, and everything works just fine.
Does Dell lock their BIOS down if non-Dell parts are installed? And is there a trick to bypassing this?
Battery is the Dell 69KF2
Edit: The picture is the error I receive when plugged in
画像
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
5 件のコメント
With the new battery installed, does it make it to the BIOS or does it completely brick up?
さんによる 共有
It makes it to the BIOS, but it warns me that the battery isn’t a Dell certified battery.
さんによる 共有
So it comes up and has a warning that your battery isn't genuine and it won't let you past it?
さんによる 共有
Yes. That’s exactly it.
さんによる 共有
Yep, I believe dell has some chip that does a virtual handshake with the battery to make sure it's oem.
Edit: Sorry i can't be of much be of much help, dell is kinda funny like that and I actually just went through this same thing but I ordered from parts people to make sure it was oem.
さんによる 共有
コメントを追加
2件の回答
最も参考になった回答
The issue here is Dell uses a custom TI battery gauge which also does a challenge/response code with the BIOS; if the response is not emulated (legal issues for sites like iFixit to knowingly sell) or a Dell BMS is reset and reused (legal since it's not cloned), it will reject the pack. This started with the E series due to the D series 2005 Sony recall. The issue is now by the time it's cracked, the laptops are so decrepit it doesn't matter to Dell, and the machines are mostly retired. Maybe RtR will fix this on future machines (potentially some older models), but Dell has begun to sell batteries on their site for "internal" laptops :-). This is where you can get the "right" battery now. You can get it at a slight discount from PartsPeople as well.
While Dell doesn't vendor lock things like SSDs and RAM (even screens), the battery IS locked down. That's why you can get a garbage spec machine from them with a good CPU at a healthy discount as a factory refurb and then buy the parts you really wanted like a 1TB SSD.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Dell doesen't usually do this, so it can be a problem with the battery. Try cleaning the battery.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Yeah, I think Dell is usually pretty open about repair and parts.
さんによる 共有
I thought so too, but the photo from the BIOS is the error I receive when I turn the machine on
さんによる 共有
コメントを追加
回答を追加する
Logan Endicott さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 21
過去 30 日: 94
今までの合計 2,049
