メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Windows 10は、Windowsオペレーションシステムのメジャーバージョンです。2015年に発売されました。
Silencing the Win11 upgrade message?
画像
I upgraded my SSD from 512GB>1TB and my machine is now pushing Win11 on me when it did not do this before. I guess the restart and subsequent hardware detection change after cloning the SSD triggered it. Nonetheless I shut it down for now and told it to shush in Windows Update but is there a way to silence the startup prompt and then I can decide when I am ready? I know we could do this with 7/8.x>10 with Never10 (and yes, I DID check if Steve Gibson did it again; nope >_<) but I see nothing with 10>11 on upgradeable computers.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
@nick this "upgradeable computers." will become more and more of an issue sine thee are so many older computers out there that it will lead to many abandoned devices. I do hope somebody comes up with an excellent answer,
さんによる
@oldturkey03 Mine is 11th gen so it CAN run 11, with the TPM requirement met as well. I'm not ready. I have one of the lucky few but I'm holding out until closer to 2025.
I just want to silence it for the rest of this year and 2024.
さんによる
コメントを追加
2件の回答
ベストアンサー
This may possibly work though written for W10. Click below:
Never 10
If that doesn't work there is always the freeware
Winaero
Type "Update" in the search box on the top left and select "Behaviour\Disable Windows Update". Check the box in front of "Disable Windows updates and notifications"
It works on my computer. Let us know how it goes for you. There other possible tweaks but they are more complicated.
Then again there is the Group Policy Editor
To disable Windows update notifications using Group Policy Editor:
  1. Press Win + R to open the Run dialog box.
  2. Type gpedit.msc in the box and press Enter.
  3. In the Local Group Policy Editor window, use the left pane to navigate to Computer Configuration > Administrative Templates > Windows Update > Manage end use experience.
  4. Double-click the Display options for update notifications policy on your right.
  5. Select the Disabled option.
  6. Click Apply followed by OK.
Here is another tool:
InControl
This may help. It only allows Security updates.
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
I tried. Nope.
さんによる
Hi @nick,
Which "nope" was that? Never 10 or all three?
さんによる
@aactech Never10
さんによる
Nothing works win 11 spam ad comes back
さんによる
@rtcharger Look at "InControl" in answer edit above.
さんによる
コメントを追加
最も参考になった回答
If you are able to disable TPM in the BIOS, that should silence it. Windows 11 requires TPM to be installed per the minimum requirements. Windows 10 might still bug you to "upgrade" to a compatable computer, but there won't be a startup prompt.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Nick さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 48
今までの合計 1,322
