メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How can I fix this monitor?
This was working perfectly until it during use it make a click monitor went dark. It seems to still light up in some way, just no display. Even the built in menus are not visible. Any chance I can fix this myself? Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @doriancussen
Seems like a problem on the mainboard given that you have no display and also no menus either but it could also be the power board as well.
The "...seems to still light up in some way..." appears to indicate that the backlighting in the screen is working so some parts of the power board are still working at least.
Bit of a vague answer I know so the best I can suggest is to open the monitor and visually inspect the boards for any obvious component damage i.e. bulging or leaking capacitors and any burnt out or heat stressed looking components.
Unfortunately I couldn't find any schematic diagrams for the boards, you may have better luck.
Here's the disassembly procedure that may help.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Dorian Cussen さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 41
今までの合計 1,011
