メインコンテンツにスキップ
2020年11月発売。MacBook Pro 13インチモデルは、8コアのCPUと8コアのGPUを搭載したAppleのArmベースのM1 SoC。(モデルA2338 / EMC 3578、Thunderbolt 3ポート2基搭載)
115回答 すべてを表示
Mac does not start unless battery is disconnected and reconnected
My Mac currently won't boot, it won't respond to anything even when I plug it into the charger. The problem is solved when I open it, disconnect the battery from the logic board and reconnect it. Then it works for some time, but at the latest after 1-2 days the problem comes again. I can't unscrew the device and reconnect the battery every time. The battery itself seems to be in good condition, Coconut Battery shows good values, it also lasts a long time.
Please help me, do you think the problem is with the battery or the motherboard?
Kind regards
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
After resetting SMC restart the system enter into the onboard diagnostics to see if something pops. If that doesn’t help focus things you’ll need to do a good inspection of both sides of the logic board looking for stains or burnt components.
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
I tried, but when entering diagnosis mode, it keeps saying that a diagnosis is not possible as the an error occurred, try again...
さんによる
@vegotech - Ouch! Sadly the logic board has an issue. If you don’t have the skills or tools it maybe best to seek either an independent Mac repair person or Apple.
さんによる
Are you 100% sure?
さんによる
@vegotech - As best as I can be from years of experience fixing Mac systems. The onboard diagnostics is built into the systems firmware. So it is at the lowest level, below the OS so if it is ha I let’s deep!
さんによる
コメントを追加
回答を追加する
vego.tech さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 34
