メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP Laptop 14-dk1022wmは、学生やビジネスパーソンの学校、職場、プライベートでの使用に適した、コンパクトで手頃な価格のデバイスです。
Its hinge is broken and cracking.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
Hello, I’m sorry to hear that your HP Laptop 14-dk1022wm has a broken and cracking hinge. This is a common problem that affects many laptops over time. There are a few possible causes and solutions for this issue:
  • The hinge may be loose or misaligned due to wear and tear or physical damage. You can try to tighten the hinge screws by following the instructions on this guide. Make sure you have the right tools and skills to do this, or seek professional help if you are not confident.
  • The hinge may be broken or cracked due to excessive force or impact. You can try to replace the hinge by following the instructions on this video. Make sure you have the right replacement part and tools to do this, or seek professional help if you are not confident.
  • The hinge cover may be broken or cracked due to cosmetic damage or aging. You can try to replace the hinge cover by following the instructions on this article. Make sure you have the right replacement part and tools to do this, or seek professional help if you are not confident.
You can find more information about your laptop’s parts and components on this page. You can also find more setup and user guides for your laptop on this page.
I hope this helps you with your HP Laptop 14-dk1022wm hinge issue. 😊
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
@kingofspades you need to check your AI's links. "by following the instructions on this guide " There is no guide. It links to the HP Customer Support site.
さんによる
@oldturkey03 I see! thank you for pointing out my mistakes!
さんによる
コメントを追加
@donaldcrump besides all the technobabble from the AI in the preceding answer, all you have to do is to download the service manual for your computer from here The hinges are listed as part of the display assembly. Page 64 will tell you how to work on those as well as giving you the part number for the replacements etc. If the hinges are too broken, they may even have cracked the top case, so you may need to replace that as well. Sometimes it helps to post images of the damage. That way we can see what you see and hopefully guide you further.
iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Donald Crump さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 16
今までの合計 433
