メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Running only on the lowest setting
My Miele vacuum, ECOTEQ PLUS only runs on the lowest setting, which means there is not much power when sucking up dirt. The buttons which allow me to increase suction don't respond when I press them. Can anyone help me what to do? I would like to avoid calling out a Miele expert as it might be expensive and difficult living in the countryside in Mid Wales.
Thanks for any tips.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
I had the same problem with the Miele c 3. De button to lower the power was stuck. This has probably to do with opening the c3 to change the bag and filters. With a bit of silicone spray and a gentle “ stirring “ with a screwdriver the button was working again. Problem solved
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Tanja Bolenz さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 12
今までの合計 264
