Why am I getting code 9c8?
In the middle of spinning it started sounding ding and had code 9c8. I’ve already done update about fire recall. What now?
It's a software update issue.
Press and hold the start button to clear the error code. then hold the Smart Control button for 3 seconds and then the temp button for 7 seconds. Then turn the machine off and back on.
このアンサーは役に立ちましたか?
That did not work
That did not work. I soregret buying this washer, is a junk
Did not fix issue
@brendamay70158 same make and model? What are the issues? What all have you tried?
I cannot find the smart control button.
過去 24時間: 0
過去 7 日: 4
過去 30 日: 31
今までの合計 5,003
2 件のコメント
Way am getting a code 9c8
kenny bruce さんによる 共有
@kennybruce25022 9C8 - Software Overcurrent Error which appears to be frmware related. It is also possible that this is a hardware defect with the main control board or motor
oldturkey03 さんによる 共有
