メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Bullitt Groupが製造したAndroid搭載の折りたたみ携帯電話。2021年にCaterpillar Inc.のブランドライセンスのもと、CAT phonesシリーズとして製造されました。CAT S22という名称でも知られています。
Pogo connection positive / negative side
I want to 3D print a charging cradle for my CAT S22 FLIP phone. I can't seem to find any information online as to which side of the pogo connection is positive and which side is negative. If anyone out there knows the answer, please let me know. Thank you in advance.
P. S. If you need photos of the phone and the cable that I plan to use, let me know and I will send them. Thank you.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
4 件のコメント
Will you be posting the result anywhere when you are finished? I am also wanting to print a charging dock and would love to see what you come up with
さんによる
Yes I will be posting an update. I'm currently waiting for the charging cable to arrive. And a friend is going to let me borrow his multimeter so that I can figure out which side is positive / negative. I still can't believe that CAT never made a drop in charger!! Why have the connections there if you're NOT going to offer a charging cradle?? And their online "chat" feature... They REFUSE to answer the question on which side is positive / negative!! So much for their "customer service"!!!!!
さんによる
Hi Scott
Did you contact "bullet", the producer of the CAT phones?
Any way I would like to own 2 or 3 cradels too. Can't print my self though...
If you had former information that might help me, please let me know.
I 'm on the mail list since today
Best Albertjan
albdijk@gmail.com
さんによる
I want to do the same- did you find or make a 3D file- if so, can I get a copy? Thank you,Ken it045@yahoo.com
さんによる
コメントを追加
2件の回答
最も参考になった回答
Hello! Bit of a long shot, but I wonder if those contacts will be tied directly to the normal charger connections, you could try to measure them with a multimeter while the phone is on charge! @scottantho50551
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Looking at the phone from the rear, with the pogo pins at the bottom, the positive terminal is on the left. Connect your charger positive to positive, negative to negative. The pins are 8mm apart.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Confirmed, + on left/ - on right and measured (while charging) voltage 5.2V DC So it's probably directly connected to the side USB (C) plug on the phone. Best on your project. Dr. Bob ;-)
さんによる
コメントを追加
回答を追加する
Scott Anthony さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 32
今までの合計 2,145
