Proximity sensor not working
Proximity sensor is not working when we call someone screen goes off and start after pressing power button 2 times
Hello @nikhilchhaproo ! Fellow wing user here, just to check, are you running the latest update available? Things can be quite buggy on the older versions.
Thanks!
このアンサーは役に立ちましたか?
Some features of app are not working properly but on the same place of screen some app features well. I didn't get How's that? 🤔
I look forward for my comment to give you people hope but mine just started to show the same failure a couple days ago but today turned out the issue fixed itself. By the way this thing started after I charged the battery with an unofficial power brick and fixed after a night long charging cicle with the same one. I always charge it with the official one.
このアンサーは役に立ちましたか?
Open the Wing, you will find that the back panel where the proximity sensor is located has a protective seal. Peel it off.
Enjoy the Wing, fly high my friend.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 5
過去 30 日: 25
今までの合計 726
