メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Western Digital社製の250GB 3.5インチSATAハードドライブ。
Hdd is not getting detected
When i turn on the pc harddisk turns on and then turns off after 10-15 seconds. I want to recover my data from that disk. I tried to contact manufacturers of that disk but they say that disk is a copy and not a genuine one. I also tried to connect that drive to other pc but there also not getting detected
What should i do ?
That data is very much important to me. Please help
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 10
1件のコメント
I have already recovered some HD's by removing the electronic board and resoldering it with the hot air rework station.
さんによる
コメントを追加
2件の回答
最も参考になった回答
@khushaldhumane explain to us what this means "they say that disk is a copy". There are two possible failures, The controller board or the mechanical part. If it is mechanical, you want to leave your hands off and send your drive for data recovery to a place that specialize in this. Those are not cheap.
For the controller issue, you could try to replace the controller board. I've done that a few times and successfully removed data from those drives. But, you will need to get the right board etc. Not always an easy find. Check this guide for what I am referring too,
Hitachi GST Deskstar HDS721010CLA332 ハードドライブのコントローラー交換
If you need more info or guidance, post some good pictures of your board etc. with your Question. that way we can see what you see.
iFixitでの質問に画像を追加する方法
iFixitの画像
ガイド
難易度:
とても簡単
2 - 5 minutes
Hitachi GST Deskstar HDS721010CLA332 Hard Drive コントローラーの画像
ガイド
難易度:
中レベル
20 minutes
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I am also stuck in the almost same situation. In this case, put your HDD in the sun for around 1 hour, then let it cool down for 10 minutes, and then insert it. In some cases, the HDD is fully recovered, and in some cases, it shows up in your PC for around 5-6 hours or a day. I recovered my data with this method.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Khushal Dhumane さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 24
過去 30 日: 149
今までの合計 3,826
