Inside screen not working
When inside screen is folded out it doesn't work . Only works on front screen.
Sounds like your inner screen has failed and needs replacement. Samsung took a screen and "designed" it to fold when it really shouldn't be folded over and over again. These OLED screens are already difficult and expensive to manufacture as is, now they just added a layer of complexity and even more wear and tear all while charging more.
このアンサーは役に立ちましたか?
Does is it function the same if the inner screen is not working
このアンサーは役に立ちましたか?
Yes it does.
What it cost 2 fix 2 unlock it n the screen n where can I take it living brantford Ontario
このアンサーは役に立ちましたか?
The bottom half of the screen n 2 unlock
It's broken and won't turn on and the bottom half of the screen won't work
過去 24時間: 2
過去 7 日: 6
過去 30 日: 47
今までの合計 1,467
