Tea went into my screen and giving a splotch.
Some milk tea fell on my screen, I kept it in tent position and then this happened
Sadly sometimes flipping the system over makes a bad situation worse! That is what happened here the spill along the bottom inverted it’s travel which in turn got into your display deeper.
At this point there is little one can do to undo the damage. These displays are very hard to open up without adding more damage. Even still the tea will have stained the defuser surfaces so it will still be present in the end.
That leaves only one option replacing the lid. Ouch!!
Here’s our guide MacBook Pro 14インチ 2021 スクリーンの交換 you’ll need to go here to get the part Apple Self Service Repair
I hope you’re sitting down as the part is quite costly!
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 7
過去 30 日: 15
今までの合計 43
