メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Galaxyスマートフォンの大幅な進化 ハイエンドな特長と機能を搭載しています。
Why is my charging point not functioning
Why is my phone not charging
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@gospelbesty you are not giving us a lot to work with here. The A series is a lot of different models. To be specific, we would need to know your phones exact model number. We can however, provide you with a couple of ideas.
Always make sure that your software is updated etc, Assuming that you checked your software/firmware, the next thing to do is to check it systematically.
First check your charger. Make sure it has proper output. Then check your charging cable. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a USB ammeter and see if your phone draws any amperage from the charger. If it does not it is possible that this is a charging port issue or a bad battery.
To check the charging port,use a voltmeter and measure the voltage on your battery connector. Next plug your phone charger in. Now measure the voltage on your battery connector. That voltage will have to have increased. IF not then the issue is either the port or the charging circuit.
The A series has issues with the flex cables coming from the charging board to the main board. CHeck that for micro tears and corrosion and proper connection to the boards. I suggest that you start with a new battery if any of the above did not work. After that it's the charging board and flex cables.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Gospel Besty さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 24
今までの合計 296
