メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Dell Latitude 7420モデルのDell Latitudeデバイス。カーボンファイバー製の筐体、タッチスクリーン、ロック解除用の指紋リーダーを備えています。
Where is the CMOS Battery?
Where is the CMOS Battery located on the Dell Latitude 7420?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
2 件のコメント
Cmos battery is inbuilt with battery.
さんによる
Where do battery smos
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Hi @splitintwain
There is no separate cmos battery connected to the motherboard in a Dell 7420.
The RTC (Real Time Clock aka cmos) battery supply is provided by the main battery.
Here is the service manual for the laptop.
Go to p.27 (or p.30 depending on battery type installed), to view the procedure to remove the main battery.
Take note that it mentions that by disconnecting the battery that the laptop is RTC reset i.e. the BIOS settings will be reset to the default factory settings.
If you wish to reset the BIOS and restore any possibly corrupted settings by removing the battery you simply have to disconnect the battery cable from the motherboard and not remove the battery itself.
It may also be prudent that once the battery cable has been disconnected to press and hold the laptop's power button for 15 seconds, to ensure that all the residual power stored on the motherboard has been drained as well, before reconnecting the battery cable to the motherboard.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thank you, @jayeff, that is very helpful! And it also explains why I could not find the battery after a complete disassembly of the laptop. I appreciate the quick response!
さんによる
コメントを追加
回答を追加する
splitintwain さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 53
過去 30 日: 173
今までの合計 8,964
