front light went out
front led stoped working but timecapsule works fine.
この質問は役に立ちましたか?
The average life is about 18 months. If your computer is under AppleCare take the Time Capsule in for replacement. I read on this for about an hour. Main problems seem to be overheating and bad capacitors. There are instructions on replacing the capacitors on some sites. It's a very well know issue. Back up to something else in a hurry. Here's just one of the Apple threads on it. http://discussions.apple.com/thread.jspa...
このアンサーは役に立ちましたか?
Good to see you here Mayer.
To be clear, is your time capsule functioning properly? Or do you just hear it running but it is not responsive or recognized on the network? The following would apply IF the Time Capsule front LED is not lit when plugged in, but you can hear the fan and possibly the drive attempt to spin up (usually never achieves full "throttling" speed for normal use under this condition.
The probable Issue: (Anecdotal) One of my time capsules, in between being moved physically and unplugged, refused to function properly after being plugged back in. The LED light would not turn on, the drive would audibly spin, and it was never recognized (networking, plugged in, etc).
The Problem Diagnosed: After some testing, was the breakdown of solder joints (much the same as some of the old macbook pro logic boards with GPU issues, etc). The joints had broken (microscopic breaks) and were not totally functioning in every spot. Because I don't have rework equipment (have to ask to access it and I don't like asking for favors), I decided to try a home remedy on something I knew was dead and didn't mind if the attempted repair didn't work.
Method: Completely disassembled the time capsule, and stripped down the main PCB (printed circuit board)... stripped free of any soft plastics, tape, etc (anything that would melt or burn under heat). NOTE: There's a clip on the back of ports that is a plastic locking clip... you wouldn't notice it unless you're looking. BE SURE TO REMOVE THIS. It would melt under heat and ruin the inside of the ports.
After you're sure you've removed everything, clean the board with a toothbrush or some other very soft bristled brush and soapy water. You could use 90% rubbing ETOH, and then soapy water, but I don't think it's necessary. Clean the board off thoroughly - but gently.
(NOTE - I have to go to shop to use rework equipment and it's a bit of a hassle --- I usually save up a number of boards to work on and do them in a period of a week or so, so I attempted this method with the knowledge that this could damage the board)
PREHEAT a kitchen oven to 395 degrees (use a good oven that maintains the temp well... not a cheapy in some rental apartment that will fluctuate. This part is important, and I can explain why chemically if you want to message me). Prepare a cookie sheet or something similar with a sheet of aluminum. Make a couple of balls with additional aluminum. Position the PCB ("processing chip" faced upwards) on the balls (or "support pillars), being sure not to position the balls touching plastic parts. Contact of the aluminum balls with small plastic ports will likely cause them to melt. The idea here is to be exposed to even heat all over, making as little direct contact as possible with heated surfaced. You want the ambient heat, not contact heat. The same could theoretically be achieved with a quality heat gun, but most people are not talented enough to apply even heat for a duration -- even myself (although I've used my hako heat gun - a rather expensive quality model -- plenty).
Put the tray with the PCB positioned properly in the oven (once preheated), times exactly for 8 minutes. No more. You could play with less if you were wanting to be super cautious, but it might mean assembling and disassembling multiple times. I've tried this a number of times with failed PCBs from broken solder joints I could only spot with infrared. This is my "best practices" method.
After 8 minutes, carefully remove the tray (steady handed... you don't want the PCB to shift off the pillars, or roll off and touch the tray. It will burn the board). 10-20 minutes later, when you're sure the board has cooled, reassemble the parts back to the PCB, and then reassemble the time capsule.
It should work if you're careful. NOTE: This COULD potentially help a dead board as well, but this suggestion is primarily targeted for boards like mine that showed they were successfully powered, but not functioning properly (and thus, the time capsule not functioning).
Questions?? Post here, and I'll answer. Cheers
このアンサーは役に立ちましたか?
WORKED LIKE A CHARM! AM WELL CHUFFED! Wondering what other things i can bake back into life now... pretty sure my old crucial m4 ssd must be worth a shot ;)
Hello to all. Thank you for this update. It has also worked for me. I left the device for the for throwing away over a year ago as warranty was out. After stumbling on this thread I decided to have a go at it. I followed the steps as above and just like magic… last night I once again had a working Time Capsule.
Thank you for posting.
Worked for me. Thanks a lot!
Worked for me, thanks for the detailled instructions!
First suggestion would be turn it off, wait 30 seconds, and turn it on again.
Does the internet connection still work fine?
このアンサーは役に立ちましたか?
LOL... always forget to mention the obvious. Thanks Rab.
This also worked for me. Thank you!
WARNING: I broke the socket for the heat sensor plug when trying to disconnect it.
The socket came away from the PCB so be careful when disconnecting it.
Everything works but now the fan runs full speed all the time.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 7
過去 30 日: 25
今までの合計 15,282
2 件のコメント
http://timecapsuledead.org/
mayer さんによる
I have the same problem, how can I fix it???
Jahanshah Saleh さんによる
