メインコンテンツにスキップ
2020年11月発売。MacBook Pro 13インチモデルは、8コアのCPUと8コアのGPUを搭載したAppleのArmベースのM1 SoC。(モデルA2338 / EMC 3578、Thunderbolt 3ポート2基搭載)
115回答 すべてを表示
Horizontal flickering lines on screen, depends on display angle
Hi everyone, I have issue with my macbook pro m1 late 2020. It started from nowhere, horizontal flickering lines just showed up, when topcase is nearly closed everything is fine. Check out video YOUTUBE . I guess its problem with flex cable but witch one? I want to try repair it on myself because service wants to change display for like 600$. Anyone had similar issue and know exactly which cable should I change? Thanks!
Update (08/23/23)
Photo of my cool screen :)
Update (08/24/23)
Thank you for answers, that is sad :(. Anyway I found a guy on youtube who did similar repair, I will try to reach him and maybe I will save some money but definitely no time :D. I will come back with update. Have a great day everyone!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Yup! The display cable is damaged. There are two display cables (two outside cables) one carry’s the backlight power and vertical signals and the second carriers the horizontal signals. Reference Step 29 in this guide to see them MacBook Pro 13インチ Two Thunderbolt Ports Late 2020 ディスプレイアセンブリの交換 the smaller ones are the camera and photo sensor and active camera LED.
These are not really repairable as they need to flex.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
If I might expand a bit on Dan's excellent commentary, not only aren't they repairable, but because they're bonded directly to the glass and the electrical circuits etched into the glass, they're not replaceable either.
Which explains the price quote for replacing the whole display, since that's the only repair possible, at least to us mere mortals.
さんによる
Thanks! @dadibrokeit
Dog was insisting on a dog walk. I thought dog serves man not the other way 🥰🐶😏
Even a brain surgeon can’t fix this!
さんによる
コメントを追加
回答を追加する
Antek さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 88
