Why is camera not turn ON
Camera not turning on
@priyeshcamera if you are sure you have a good battery and if your battery case door functions properly, time to take it apart. Use this guide Sony Cyber-shot DSC-S2100のLCD交換 to get into your camera. Once there, you need to check the motherboard. Make sure that the battery cables are properly attached and then check the fuse for continuity. One is the power fuse.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 28
今までの合計 1,313
4 件のコメント
Hi @priyeshcamera,
Have you tried using new fresh batteries in the camera to see if it turned on, you didn't say?
jayeff さんによる
Yes, I already checked it
Priyeshcamera さんによる
Start problem not running
Binod Saw さんによる
Camera is 1year old please recover
Display is on but don't work さんによる
