How I enable files application
How i enable files application
Update (08/16/23)
I accidentally disable my "files" application now i cannot find a way to enable it. It shows in settings "apps and preferences".
It seems like you're asking about enabling the "Files" application on a specific device or operating system. However, you haven't mentioned the platform or device you're using. The process can vary depending on whether you're using a Windows PC, macOS, Linux, Android, iOS, or another operating system.
Here are some general steps for enabling the "Files" application on common platforms:
If you're referring to a specific application named "Files" or a different context, please provide more details about the platform you're using so I can give you more accurate instructions.
このアンサーは役に立ちましたか?
I m using android sony xperia xz3. In playstore it shows the other apps not mine one which i accidentally disable
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 9
過去 30 日: 30
今までの合計 609
@abdulahad27711 you do not provide information about what the problem is. You need to be clear with your question and provide as much detail as possible to get any help with this.
oldturkey03 さんによる 共有
