Display vertical and horizontal lining issue
Display lining issue no clear picture what is problem
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
7 件のコメント:
@ratishulvekar post a picture of what your screen shows you, with your question. We need to see what you see iFixitでの質問に画像を追加する方法
さんによる
To add to the above, we need a picture of the issue but if its really thin, maybe single pixel wide, lines that are (from what I've seen personally) usually green, red, or black - its likely that strip of pixels failing or physical damage. Which isn't often repairable without replacement of the LCD screen itself as far as I know, unfortunately.
Can't help diagnose without a picture though.
さんによる
I have the same horizontal line issue
さんによる
I am facing horizontal line issue can it be repaired or I have to change the panel.
さんによる
@upasanadutta post a picture of what your screen shows you, with your question. We need to see what you see iFixitでの質問に画像を追加する方法
さんによる
2件以上のコメントを表示
コメントを追加
