メインコンテンツにスキップ
2.2 GHz (Turbo Boost使用時最大3.4 GHz), 2.5 GHz (Turbo Boost使用時最大3.7 GHz)もしくは2.8 GHz (Turbo Boost使用時最大4.0 GHz) L3キャッシュで6 MBのクアッドコアIntel Core i7プロセッサ
781回答 すべてを表示
Replacement Battery only charges to 57%
I recently replaced the battery in my 15" 2015 MacBook Pro. Imediately after replacing, I began the battery calibration process by plugging the power adapter in and charging. However, the battery only charged to 57% and when I clicked on the battery icon, it said "Power Source: Adapter - Battery Is Not charging". I looked this up and the common answer to this was to reset the SMC. I followed this process and when the MBP powered back on it showed 100% charged so I thought that did the trick. I left it plugged in for a few more hours and then unplugged to continue the calibration process. This wen't fine except my battery registered at around 51% at least the last time I had looked, before shutting off due to low battery with no low battery warning. I figured this was because the battery was not calibrated yet. I waited 5 hours and then plugged it back in. The batter charged up to 57% again and stopped. Same message when clicking the battery icon. Did I miss something in the process, or is there something else I can do to fix this?
Update (08/11/23)
Here is a screenshot of Coconut Battery. It looks like the capacity is accurate, but for some reason the mac has just stopped trying to charge it.
Update (08/12/23)
I decided to try the SMC reset and see if it would either resolve the issue, or if not at least CoconutBattery could show some more details. I used what I believe is the correct method for this model (Hold Shift, Control, Option, and Power button for 10 seconds, then power on). The above image is from Coconut Battery immediately after powering on and login in.
This image was captured about 5-10 minutes after. This behavior was pretty much what happened after the first SMC reset. Not sure what it means.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Let’s get a better view here install this gem of an App CoconutBattery post a snapshot of the apps main window so we can see what’s happening as it’s plugged in.
Update (08/12/23)
@danschaibly - it looks like the system stopped charging as the batteries temp was elevated! 84 degrees is within the cutoff range! Let’s disconnect the MagSafe and shutdown the system for a good four hours.
With the charger still disconnected restart and take a fresh snapshot, then try recharging again. Monitor the temp, you might want to install this great app TG Pro which can log your systems temps with the full version. Even still the trial version will allow you to see things at a glance, here the batts temp.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
The temperature is in degrees Fahrenheit. It's actually not too much warmer than room temperature, and about 29 degrees Celsius. Are you sure this is an elevated battery temperature?
さんによる
コメントを追加
回答を追加する
danschaibly さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 18
今までの合計 86
