メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
10代目Corolla(E140/E150)は2006年10月に日本で発売されました。日本ではナローボディ版が販売され、その他の地域ではワイドボディ版が販売されました。
How to close airbag light
Airbag light is coming on speedometer
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
2 件のコメント
Why is my airbag light show on my dashboard
さんによる
Yes I have a light for a airbag it's saying chack your airbag
さんによる
コメントを追加
3件の回答
最も参考になった回答
If the airbag light just came on, it usually means that there is a problem with the airbag system, so resetting the light isn't going to fix the problem. I would start by diagnosing the airbag system and figuring out and fixing the problem before resetting the light. If your car has a worn seatbelt (given the age) that might be the cause of the problem, rather than the airbag itself, since the restraint system has to be in working order for the airbags to work properly.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
To add to Chaya's excellent advice, most general purpose scan tools cannot reset an airbag light; it usually requires a dealer tool to access the airbag system. So even after you fix the problem you will most likely have to find someone with the proper tool to turn the light off.
If you do find someone with the proper tool, they will be able to scan the airbag system and tell you why the light is on in the first place; that will tell you what needs to be repaired. It could be as simple as a broken wire on the seatbelt or as dangerous as a defective airbag; no way to tell at this point with the information you have.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
My toyota corrolla has 4 recalls for the airbag light to a main toyota dealer and it still hasnt been fixed its okay for a while but comes back on again after a few weeks or in some cases days
さんによる
@witsend25111 Sounds like time to find a different mechanic to take a look at it. Despite whether they have certifications like the ASE, not all shops have the same level of expertise, so try another one since your current mechanic doesn't seem to be able to solve the problem.
さんによる
コメントを追加
Most of the time you would to check the connection under either the passenger seat or the driver's seat and then make sure they are not loosen
Once upon a time I had my Airbnb light on it kept bothering me I thought I had to replace the whole airbag untill I put a diagnostic machine on it. It identified the right passenger seat I just had to pull the seat forward and then check the yellow cable beneath which is mostly the airbag cable once I adjusted it the light went off and that was it. Untill now it hasn't ever shown again
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
pranshul ghavri さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 20
過去 30 日: 148
今までの合計 6,329
