メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Apple設計のM1 ProとM1 MaxのSoCを搭載した14インチMacBook Proの修理ガイドと分解情報をご紹介します。2021年10月に発売。モデル番号はA2442。
Right Fan Not Working
Hey guys,
Right fan of my girlfriends' macbook 14 pro 2021 is not working. Actually it tries to work under load but it increases the fan speed from 0 to 20k and beeps when I can with macs fan control. It keeps beeping periodically. The question is, if I remove the back cover and disconnect right fan will the mac start? The most demanding app she is using is zoom, on average she works with chrome and spreadsheets. As she is using it like this for 4 months without right fan, I don't think it will be a problem for disconnecting the right fan. But the question is if it will start the mac or not without the fan. Before removing the cover I wanted to ask, I will be glad if anyone knows the answer.
Best
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
The beeps is telling you something! Instead of second guessing disconnecting the fan will fix this how about getting a better idea what the problem is.
So… Restart the system and press the D key it will enter into the onboard diagnostics. Let’s see what it tells you.
Reference: Mac startup key combinations
And no disconnecting the fan is not a wise action as SMC will loos access to the fans Tach and do two things ramp up the fans speed as well as lower the CPUs clocking to prevent damage.
All it will do is confuse you on what’s needed to truly fix your system.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Shinanai さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 19
今までの合計 270
