Phone want charge low temp
Phone want charge says low temp
@amandaj35820 this is usually battery related. The contacts for the battery temperature sensor are near the top of the charger. Try to attach the wireless charger to the phone. Once it is connected try to turn the phone on. If your wireless charging pad has failed, you an also get the same message. In your case, I'd start with a new battery. Use these guides Samsung Galaxy S8 Plus to work on your phone.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 4
過去 30 日: 16
今までの合計 290
