メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
現在は Briggs & Stratton が所有する Murray ブランドの乗用芝刈り機に関する修理ガイドとサポート情報です。
Why is my engine not starting
I have a 17hp techumseh engine on a Murray riding mower that tries to start but won’t. It fires enough to kick the starter out but won’t go ahead and start. I’ve cleaned carb, set valves, checked spark, (blue) and checked crankshaft key….I can’t figure it out…it was running good until I ran over a motorcycle tire in tall grass I didn’t see….it was still running for a bit after I hit the tire, (it was just the rubber) and then bogged down and died…
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@baddeal I wonder if the motorcycle tire did not throw off your timing. How did you check it? what exact engine is your Tecumseh? Something like a Enduro Ohv17 etc. Most Tecumseh ignition module depend on the flywheel key for a proper ignition timing. By your running over the tire, it is possible that this partially sheared the key, which will offset your timing. I would definitely take a look at that and replace the key.
Update (08/06/23)
@baddeal I just received this Tecumseh 4cycle OHV Engines. It is engine specific. See if that gets you a bit closer.
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
I pulled the flywheel and looked at the key…,it was fine. It’s a 17hp ohv..
さんによる
@baddeal I would check to see if it starts if you spray some starter fluid around the air intake. I would check the air gap as well just to make 100% sure it is not ignition related. After that it's a fuel issue. You've checked your carb, so you know the choke is not choking your engine. Your float is working properly and the needle valve does it thing. I believe your tecumseh has a impulse fuel pump. You may need to check fuel delivery to your carb.
さんによる
Sprayed lots of starting fluid….no start…
さんによる
Like I said….it has a blue spark and timing seems to be right…..it hits enough with starting fluid to kick the starter out…
さんによる
@baddeal this 'Sprayed lots of starting fluid….no start…" is weird. With spark it should just kick in and at least give you a few rotations of running. Do you have fuel in the carb bowl?
さんによる
コメントを追加
回答を追加する
Bad_Deal さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 12
今までの合計 377
