メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2022年発売のフルサイズ冷蔵庫、Frigidaire Refrigerator FRSS2623A*に関する修理および補足情報です。本モデルは内蔵型やドアスルー機能のないモデルですが、自動霜取り機能を備えています。このページは、FRSS2623A*のパターンに合致するモデル番号に関する情報を扱います。
Frigidaire Freezer Not Dropping Ice
Hi all,
I have a side by side Frigidaire freezer/fridge, model number FRSS2623AS6.
Water will enter the cube tray fine and freeze, but will not drop. When I cycle the control panel on and off (green button), the tray begins to rotate, but the feeler arm doesn’t go all the way down. If I manually push it down gently, it will go down and drop ice, then fill back with water.
I attempted defrosting for a little while, but that did not work. I haven’t taken it apart to see if maybe something is stuck or out of alignment with the feeler arm and motor inside. I’ve also attempted a reset, which also did not work.
I’ve attached a picture, and video at the best angles I could get with the bin still installed.
Any suggestions or thoughts?
Thanks so much!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
First thing I would do is to pull it out and let it completely defrost:
https://www.subzero-wolf.com/assistance/...
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Ok will try that in a few and see. Thanks.
さんによる
That was it.
I haven’t fully reinstalled, just plugged the harness back in to check if the feeler arm goes down on its own, and it did, once for drop, again for water recharge.
Going to let it sit out and fully evaporate any remaining liquid so it doesn’t refreeze after reinstall.
Thanks!
さんによる
コメントを追加
Hi @nicklemay
If it still doesn't work OK after you reinstall it, here's the service data sheet for the model series, that may help.
It describes how to manually run a test cycle on the ice maker.
If there is a fault and a replacement part is required, here's a parts list that may be useful.
Scroll across to the ice maker parts diagram to find the part and then the part number for the part. Then search online using the part number only to find suppliers that suit you best.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
This is also very useful, thank you.
さんによる
コメントを追加
回答を追加する
Nick LeMay さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 41
今までの合計 2,635
