メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
この端末は2018年5月に発売され、Android 8.0 (Oreo) がプリインストールされていました。
touch screen not working
screen lights up , but does not respond to touch . can't enter pin lock .
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 6
2 件のコメント
My phone is switch but don't want to touch
さんによる 共有
@cynthiamadiba same treatment as the original answer points out.
さんによる 共有
コメントを追加
2件の回答
最も参考になった回答
@sanjaysankolli it is possibly that this is a software issue. First, I'd try to go with what Samsung recommends, which is basically a soft reset.
  • On devices with a Power key: Press and hold the Power key, and then tap Restart. Tap Restart again to restart your device.
  • On devices with a Side key: Swipe down from the top of the screen to open the Quick settings panel. Tap the Power icon, and then tap Restart. Tap Restart again to restart your device.
Of course, you could also try a hard reset, but that will delete all of your files, pictures etc. To me that would be the very last thing I'd try.
My gut feeling is that this is a hardware issue. For that you will need to replace the complete display assembly.
Use something like this video as your guide.
Replacement assemblies are readily available online, just make sure that you get one for your specific model (J400F/DS or J400G/DS).
If that still does not resolve your issue, then you are having issues with the circuit board. Let us know what you find you find out.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
my phone is dropedfor high place and full screel black and not working
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Sanjay Sankolli さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 21
今までの合計 1,616
