メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Appleが2020年に発表したメインストリーム向けのiPhone。10月23日に発売され、6.1インチOLEDディスプレイ、デュアル12 MPカメラシステム、5色のカラーバリエーションを特徴としています。iPhone 11の後継モデルです。
My earpiece speaker not working
My phone's small speaker for calls is not working, it just stopped working. I need to put a call on loudspeaker to hear my calls.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
最も参考になった回答
You will, of course, want to try all the software solutions you can think of, as well as cleaning the speaker grille with a soft brush, maybe some compressed air, and some 90% or higher isopropyl alcohol.
If all that fails, the fault may well be with the speaker itself. On your phone it's part of an assembly called the Earpiece Speaker Assembly. The bad news here is that replacing that assembly will kill your Face ID and the only way to get it back is to pay Apple for a full screen replacement.
However, a guy on YouTube found that the speaker is only secured by two small solder points and replacing it by itself does not affect Face ID. I wrote a guide for that procedure on the iPhone X, but it is very much applicable to your iPhone 12. Start with your Earpiece Speaker and Front Sensor Assembly guide and follow it through Step 28.
iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement - iFixit Repair Guide
Once you get there, switch over to the iPhone X Earpiece Speaker replacement guide on Step 29. That will guide you through the two small solder points you need to unsolder to disconnect the old speaker and replace it with a new one.
iPhone X Earpiece Speaker Replacement Without Losing Face ID - iFixit Repair Guide
If you decide to do this, take pictures of everything after Step 28 and use my guide as an example of how to create your own guide so people who follow after you have a guide to go by.
iPhone 12 イヤピーススピーカーとフロントセンサーアセンブリの画像
ガイド
iPhone 12 イヤピーススピーカーとフロントセンサーアセンブリの交換
難易度:
中レベル
1 - 2 hours
iPhone X イヤピーススピーカーの画像
ガイド
iPhone X イヤピーススピーカーの交換(Face ID機能を保持)
難易度:
中レベル
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Try but a new earpiece and replace it the retest.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
fethy nduli さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 34
今までの合計 489
