Why is my second screen not supported
Quadro 200D not supported dual screen
@nickletsgamerz usually there are restrictions on the resolutions for the outputs for dual screen. What is the resolution of the displays you are trying to use?
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 371
The Quadro 200D supports a dual monitor setup (https://forums.tomshardware.com/threads/...), but is it enabled in the OS? Have you installed the right drivers? Which OS are you using?
dinoo_fixit さんによる
