メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Mic problem in my phone.
Hello Sir,
Recently i got an issue in my one plus nord ce device as the person whom i am talking to cannot hear my voice in normal mode , I have to put my call on a speaker mode and then it is clearly audible to other person , what should i do .
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント:
Incoming sound problem
=== Update (10/23/23) ===
さんによる
Touch screen problem
さんによる
My problem
Mike problem
さんによる
コメントを追加
1 件の回答
Hi @divyanshrawat
Is the phone in a protective case at all?
If it is try removing it from the protective case and check if you can be heard OK when in normal mode.
If it isn't in a protective case or even if it was and you still can't be heard, use a vacuum cleaner to clear any dust, lint etc that may be blocking the small pin size voice inlet hole that is located on the bottom edge of the phone.
Do not use a pin or probe to try and clear the voice inlet hole as you may damage the microphone that is located directly behind it.
If it still doesn't work OK then there may be a problem with the microphone that is used for calls etc when in normal mode i.e. not in speaker mode as that uses a different microphone. The phone would have pt be opened and tested to find out what is wrong.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Divyansh Rawat さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 10
今までの合計 838
