メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2019年にAudio-Technicaから発売されたレコードプレーヤー。
Start button is not doing anything
The belt is on correctly, and the manual reset did not help. The start button does nothing; almost as if there’s no power.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
This is the best site for turntables I have been able to find:
Turntables, Tonearms and Cartidges
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Appreciate it! It looks like it might be a bad motor, so I'm probably in a position to replace, but I'll bookmark the site.
Cheers
さんによる 共有
コメントを追加
You may need a multimeter to check if the motor itself is dead. If it is the motor, the replacement may be available via Audio-Technica directly. The part is weirdly hard to find online otherwise. you can contact them via email at parts@atus.com. (If in the USA, check your regional Audio-Technica site for a parts page otherwise.) It will, however require a bit of soldering to replace as two of its wires are connected to another board directly instead of via a push connector.
You can see details as to how to do this in this guide for its predecessor: Audio-Technica AT-LP60BK モーターの交換
The internals are the exact same between the LP-60 and the 60X layout-wise. AFAIK the only major changes were in the physical appearance of the turntable. I would not recommend de-soldering while the motor is still in the unit (as in that old guide) as the entire shell is plastic. It's also just a big unit, which you already know due to owning one. It'd be annoying to work on it like that.
Does it indeed make a mechanical "click" when start is pressed?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jeremy R. Stoll さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 33
過去 30 日: 99
今までの合計 5,705
