I forget my password
I forget my mobile password so I rest my mobile how can you help me
A factory reset should clear all data and restore to factory defaults.
Of course, this is a problem if your data isn't backed up as you will lose it all.
このアンサーは役に立ちましたか?
Hi @ruggb,
A factory reset will reset the phone but it doesn't clear the password entirely.
If the phone has a Google account tied to it you still need to know the account ID and password to access the phone after a factory reset or know how to bypass the FRP lock (factory reset protection) that has been enabled in the phone by the reset to enable you to setup the phone again after the reset has been done. You only get so far into the setup procedure and no further as it asks for this information
FRP lock is a security feature in Android OS 5.1 and higher versions in case a phone was lost or stolen so that it couldn't be used again or onsold by simply resetting the phone back to its factory default condition as could be done with earlier versions of the OS
このアンサーは役に立ちましたか?
If you don't want lose your data you can use any tools for flashing or unlcock by any tool software. There are many tools you can use.
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 58
過去 30 日: 202
今までの合計 1,688
11 件のコメント
I don't know because I'm noob
Muhammad Fahim さんによる
I forget my phone password
Rama Mane さんによる
My phone was hanging,strucking,heating,full of storage
Mirza Mustafa Baig さんによる
hard reset my phone total reset forgo passwod unlck
manju manju さんによる
how to remove mobile paswarod
=== Update (01/07/24) ===
how to remove mobile passwrod
oppoA57 さんによる
6件以上のコメントを表示
