メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Realme C3は、Realmeが開発した低価格のAndroidスマートフォンです。2020年2月にインドで、2020年3月にフィリピンで発売されました。
My speaker did not work properly
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 12
10 件のコメント
さんによる
Speaker saya tidak ada suara
さんによる
Volume lower
さんによる
Speaker rusak
さんによる
@nurmanmila Check the original answer about the How-to replace the speaker.
Translate
Periksa jawaban asli tentang Cara mengganti speaker.
さんによる
5件以上のコメントを表示
コメントを追加
2件の回答
最も参考になった回答
@akashsingh81633 you are not telling us what it sounds like or if anything happened to the phone prior to the speaker issue appearing.
First, I would suggest that you clean the speaker grille on the external phone. Make sure that it is clean. Of course, check all your audio settings as well to ensure proper sound playback. If none of that helps, you may consider replacing the speaker. Check on something like this video for more info.
Of course, you can replace the speaker. Since iFixit does not yet have a specific guide for that, use something like this video It will show you how to replace the speaker. Replacements are readily available at many online stores. Anything after that will most likely involve some board level repair and for that check on here
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Apne najdiki mobile repair shop par jao aur use mobile de dijiyega screen Jo tooti hui hai
Thik kar dega.
Translation Hindi-English
Go to your nearest mobile repair shop and give him the mobile with a broken screen.
Will fix it.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
@deepakkuma20739 people come here for advice on how to fix their device, not to be send to a repair shop. It is our goal to empower people to fix their own stuff. So, whenever it is possible we should always provide a helpful solution for the repair to the person that asks.
Translation
@deepakkumaa20739 log apane divais ko theek karane ke baare mein salaah lene ke lie yahaan aate hain, na ki kisee marammat kee dukaan par bheje jaane ke lie. logon ko apana saamaan svayan theek karane ke lie sashakt banaana hamaara lakshy hai. isalie, jab bhee sambhav ho hamen hamesha poochhane vaale vyakti ko marammat ke lie ek upayogee samaadhaan pradaan karana chaahie.
さんによる
コメントを追加
回答を追加する
Akash Singh さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 13
過去 30 日: 45
今までの合計 2,138
