メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
ANC(アクティブノイズキャンセリング)搭載の透明な完全ワイヤレスインイヤー型ヘッドフォン
I cant pair my device
when I have to pair to the mobile phone. the light never starts to pulse. it only lights up green when I release the button
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント:
It's on light don't worked
さんによる
Hello! I also have the same problem. I cleaned them, restarted them and also updated the app and none of that worked. Note that when closing the box it does not reach the pressure of the magnet, could that be part of the problem?
さんによる
コメントを追加
1 件の回答
Hi Fredrik, did you use the nothing X app? If yes, did you use it to pair your devices together? The app (for no obvious reason) will need you to turn on your phone's location (and the bluetooth of course) in order to proceed to the pairing process. Once it's done, it'll ask you to leave the case open with the earphones still inside then keep the button pressed until the light blinks.
I'm pretty sure you've already been through all this but it was'nt mentionned on your message. I had trouble to pair it once, my right earphone was'nt showing through the app and I tried to forget it and pair it again using the app. I managed to get it working by forgetting it through the bluetooth menu of my phone after forgetting it on the app, then restart the pairing process.
Sorry for my english, not my native language. Hope it helped.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
fredrik öhlander さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 28
今までの合計 1,626
