problems after screen replacement
Good Evening!
I replaced the mobile screen with a new one and when I turned it on it was stuck in the charging state as if it had run out of battery and the device was closed. When I pressed the power button the device turned off and the same problem occurred. Do you have any idea what could have happened?
3 件のコメント
Hi Michalis,
Which screen replacement did you do; the one with the frame or the one without? There's a significant difference between those two replacement procedures so we'll need to know which one you did so we can figure out what might have gone wrong. The iFixit guide describes the procedure for the screen without a frame.
Jerry Wheeler さんによる 共有
I have Samsung A02s and went for my screen to be fixed by vendors since then the current seems not going through what is the main issue if my phone charging properly before the screen replacement
Farasisko samwel さんによる 共有
@farasiskosamwel
How long ago was it fixed by the vendors?
If only a short time e.g. 2-3 weeks, take it back to them and show them the problem.
They should have checked it was working properly before handing it back to you after the repair was done
jayeff さんによる 共有
