メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
VLT 1000 デスクファンは、直径 30 cm の 4 枚羽根を備えています。ステンレススチール製で、3 段階の速度設定が可能です。
Fan not rotating without help
Blades of my desk fan are not rotating when it is switched on
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 8
2 件のコメント
Kipas tidak dapat berputa
さんによる 共有
It's not rotating when on and need help to start
さんによる 共有
コメントを追加
3件の回答
最も参考になった回答
How old is this fan? Is it very dirty? Often spinning blade fans collect LOTS of dust, and when that dust gets inside the motor housing it can gum up the works and cause problems like you describe (though there are other causes too).
First recommendation would be to disconnect from power, remove all the housing screws to take off the housing and carefully clean and inspect the motor and other internal components. There's a chance a good cleaning will get it working again, or at least reveal something like a blown capacitor or other failed component that could be replaced to get it working again.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
I already cleaned it with contact spray. I wonder if there was any sort of lubricant for the moving parts. I’m afraid that the contact might have removed the old lubricant
さんによる 共有
@samirkardahji That is a possibility, I was not aware that you had already worked on this before the problem occured. What kind of contact spray did you use? Are you sure it is safe for all of the materials and the motors? Could it have caused corrosion or a short?
さんによる 共有
It’s a quick drying cleaning solvent for electronics which removes dirt and oil. I’m not sure what kind of lubricant required for a fan, if any.
さんによる 共有
コメントを追加
Fan does not rotate
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
First unscrew the fan blade cover , take out the fan blade , clean all the dust , then add some lubricant in bush, if the shaft is not free by hand make it free then check in power. If it isn't working yet change the capacitor of same value, fix the parts and check again.
さんによる 共有
コメントを追加
well... if the old lubricant came off that would be a problem, try wiping it off with a DAMP cloth and reapply some lubricant.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Samir Kardahji さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 15
過去 30 日: 39
今までの合計 1,857
