メインコンテンツにスキップ
2018年9月21日に発売されました。モデル番号A2097, A2098、GSM もしくはCDMA / eSIM もしくはナノSIM / 64, 256、512 GB / シルバー、ゴールド、スペースグレイ。(正しい発音は"iPhone 10 S.")
20回答 すべてを表示
Phone dead after battery and display replacement
The phone gets stuck in boot loop only when plugged in charge. Shuts completely off if unplugged. I think I might have damaged the charging port flex cable. Any suggestions?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
What you're describing typically is what happens when the battery is not plugged in. I would check your battery connection first and look for any damage to the connector or the board in that area.
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
Second this. Also try the old battery again just in case if you are 100% sure the new battery is firmly connected.
さんによる
I’ve already tried the old battery and it does the same thing. I’m hoping it’s the lightning flex cable
さんによる
コメントを追加
When you say it's in a boot loop, can you be more specific? There are a couple of types we see on iPhones; there's the one where you see the Apple logo on the screen for a while then it reboots. In the other scenario, the phone boots all the way up and then reboots every three minutes.
If you're seeing the second one, then the cause of the reboot will be logged in the analytics as a panic log. See @flannelist's excellent Wiki article on how to retrieve the panic log, then post the first page of the log here and we can help you diagnose the issue.
iPhone Kernel Panics - iFixit
If you don't get past the logo, then you'll definitely want to try out the previous suggestion of putting the old battery back in and seeing if the phone goes back to it's previous behavior. If you don't have the original battery I'd suggest going ahead and buying an new one; there's always the possibility you got one with a bad BMS board.
It's only after verifying that the replacement battery isn't the issue that I'd have a serious look at replacing the lightning port flex assembly. None of those repairs are going to be too expensive, so they're well worth a try.
Note that starting with the iPhone XS, Apple began pairing the battery to the logic board. The only way to keep the battery health information available is to save the original Battery Management System (BMS) and solder it onto a new battery cell. Unfortunately it will still have the old battery information unless you plug it into a device programmer, something like the QianLi iCopy, and use that to reset the cycle count and health percentage.
Update (07/06/23)
@korhit That is a possibility, but the only flex cable that runs under the battery itself is the wireless charging coil and the volume buttons that share a connector. Try unplugging the wireless charging coil and see if that affects your ability to boot. Here's a picture of the connector to unplug.
このアンサーは役に立ちましたか?
スコア 0
6 件のコメント:
It does not go past the apple logo only when plugged in charge. Yes I have tried the old battery but it doesn’t work. Btw I forgot to mention that I wasn’t able to pull off the adhesive off the old battery so I had to work my way around with a spudger and slowly lift up the battery. Maybe i damaged the lightning flex in that process.
さんによる
Just installed a new charging flex and also tried your option. Nothing changed, the phone gets stuck the Apple logo boot then shuts off when I unplug it from the charge. It’s like it’s not detecting a battery.
さんによる
@korhit I haven't run into this myself, but some of the guys who do this sort of thing for a living have seen cases where small components right next to the FPC connectors on the motherboard get knocked off and cause problems.
So I'd say the next step is to get out the old magnifying glass and a bright light and check all around the battery and display connectors looking for missing parts. If you can get some good pictures that might help.
さんによる
I have had this problem with a dodgy screen, or one of the grounding clips are bent, have you tried the original screen? I would take the whole thing back to original stock and see if it’s still looping, plug it in a pc and see if it disconnects continuously if the screen is totalled
さんによる
News. After i installed the new charging flex, it wasn’t working anyways. I tried the old battery again and now it seems to be working fine. Looks like I have broken the charging flex and also bought a defective battery. Very unlucky. Now i just need to try a new battery and see how it holds up 🙏🏻
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
KorHiT さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 124
